Really?? I have G Skill RaipjawsX RAM - I will try with the fan above the ram (per your picture) now and get back to you...
Just looking at some videos opn how much of the Noctua paste to apply....
This much?
If I use the U.L.N.A connector on the Noctua, will the CPU fare any less cooler? Also, should I use the Y splitter and put both fans into 1 power connector ot use CPU_FAN and ADDITIONAL_CPU_FAN on my motherboard?
Has anyone else had trouble getting the PCI Express power cable from the power supply (bottom of the case) to the EATX connector (top left of the motherboard)? It stretches just enough to go from the power supply, over the PCI-E slots and into the EATX connector!
Negative - No chance I can get all 8 on.
I have this power supply: http://www.coolermaster.com/product.php?product_id=4202 and am trying to get the PCIE-6+2 pin cable to go from the PSU to the 12v EATX port at the top of the board.
My PSU PCIE EATX 12V Cable looks like the one of the left of this image: http://www.zalman.com/images/productinfo/eng/ZM850-HP_img3.jpg . 2 square top right and 1 square bottom left. The rest are curved.
However, my P8Z68 does not match this confiuragtion as it has 4 sqaure and 4 round - like this: http://superuser.com/questions/307579/should-i-connect-two-4-pin-eatx12v-power-plugs
Any ideas? Shall I force it in?
J
