Dawelio
Active member
Hello people, I'm Chrazey!
I'm new to this forum after watching a few of OC3D TV's youtube videos.
And I thought I would post here as it seemed like a good place to post, specially after viewing other threads on here, and hopefully to get thoughts, recommendations and feedback.
I know that many of you will ask regarding a budget, and I can't say exactly what my budget is, as these are just build plans. But if I say this, even though it's a very hard scenario, but to keep it as "high end" as possible, to the lowest reasonable price.
I would also like to ask a big favor of you, if you do reply to this thread... I'd like to ask you to write down a/the reason or why you've chosen or recommend the specific component.
Although I do know the basic in building a PC etc, due to I've built my current PC, although that was about 2 years ago, so I'm a bit rusty now.
I would still like to have some advice, suggestions, recommendations etc.
So this one should act as my "main" rig, for gaming (mainly) but also for video and photo editing (Sony vegas, photoshop), music etc.
Intel i7 4770 or 4970
ASUS GRYPHON Z97 ARMOR EDITION mATX
Corsair Dominator Platinum 32GB (Blue light bars)
1 or 2 x ASUS R9 290 / XFX R9 290(X)
Corsair 180 or 240GB SSD
Western Digital 3TB for recording purposes etc
Corsair 860i PSU
Corsair Obsidian 350D windowed version or Fractal Design Arc Mini R2
ASUS 24" VG248QE (Gaming), ASUS 24" PA248Q/PA249Q (Photoshop/Photo editing) and an 17" or 19" (Other things, such as Teamspeak etc) monitor(s).
Questions:
1: GPU: I'm not entirely sure about which graphics card, as on Logan's video regarding the XFX R9 290, it seemed to run impressively quiet and cool, meanwhile maintaining resonable performance (unless he was joking).
Plus it just looks so awesome!
So which one would you recommend out of those 2?
2. GPU: In the Arc Mini R2, there are only 2 pci slots, do you people think that running a dual graphics card configuration would or wouldn't work, due to they might be too tight to each other?...
3. Motherboard: The only "concern" that I have here is about the small fan inside the back of the IO.
Does the motherboard really need it?
4. The case: I've thought of having the front dual 120's as intakes, top as exhaust and the rear as an intake, with dust filter (positive pressure inside the case, after Logan's tip/recommendation in one of his videos).
Is this a good overlay or what are your thoughts/recommendations?
5. CPU Cooler: I've been on the search after an 360mm sealed liquid cooler.
Something like the Corsair H100i, only it's an 360 rad.
I know that Fractal Design has their S36 one... but with any "new" company, that isn't really that known for their watercooling, I'm getting a bit off...
I know that Swiftech also has (and they are a well regarded water cooling company,as far as I know), their H320 and their H2O Edge HD, if I'm not mistaken.
Although, they seem very hard to get hold on... you guys know any?...
6. Fans: But what/which kind of fans should I use?... Noctua Industrial fans, BitFenix Spectre Pro (Blue LED ones) or Silverstone Air Penetrator, or which ones?...
7. PSU: How big would you guys recommend on the PSU?, is 860W too much/overkill or is it plenty for this one?...
I want to thank anyone in advance for taking your time and effort in replying and helping me out with this.
As I said above, I have built my current system, but I am still not that good at it.
Thanks!
Kind regards,
Chrazey
Corsair 860i PSU
Questions:
Thanks!
Kind regards,
Chrazey
