NeverBackDown
AMD Enthusiast
So, I'm wondering why Windows 10 is downloading an NVIDIA driver update currently....I've been on the latest 353.62 WHQL's for a few days now. No newer drivers showing up on Nvidia's own driver download page...
Hope this doesn't break something.
This is why I HATE not being able to pick and choose my updates. W8.1 would sometimes want to download an older driver than the one I was using. Plus, it doesn't give you the install option choices the proper drivers do. I.e. I disable the Nvidia audio bits and the GeForce Experience thing as they've caused me no end of problems in the past. If this update adds these, then it can fcuk right off.
Scoob.
http://forum.overclock3d.net/showpost.php?p=859725&postcount=14
Problem solved. And it's not MS fault. Its better they have this way tbh. 95% of the consumer base actually needs it.
The built in cleanup on windows can do that as well but I used CCleaner because I wanted to clean registry entries too.
No, we don't like CCleaner when it's used once a month to "fix" the performance of the PC, I was getting random BSODs so I thought a cleanup wouldn't hurt and it could actually fix some things. So many old win7 dll and registry entries found
CCleaner will find more than Disk Cleanup will. I use CCleaner and Disk Cleanup and CC always finds more. DC will find some things CC can't when searching for system files. Other than that CC is the better option.
