The Fairchild Ghost subwoofer project
Excellent idea with the magnets, that'll look great and make it feel premium. I use forstner bits mainly for euro style hinges on cabinets. Sucks lining them up perfect with a hand drill though. I make do, but I need to add a drill press to my shop... one day!
BTW coming back to this? pilot holes dude. Get a drill bit stop (these)
And just drill a 2mm hole right in the centre.
Yep I have and definitely use those. Doesn't help for the forstner bits though for what I do. On 3/4" stock it does work out to using the top of the bit itself as a guide for depth when doing hinges. A drill press would just make it easier and make it perfectly straight.
Going back to the amp.
I watch a guy on the tube and he has an amp dyno. Well yesterday he uploaded a video of a 15 inch cinema sub. He took the amp out and its identical to the one I was going to use. It said it was 150w (same) and although the two boards on it were oriented differently it was identical.
It made 46w at 8 ohms.
So I feel completely redeemed tbh. I'd have been so disappointed with the sub thinking it was bad.
OK so a slight snag yesterday. The plug does not fit in the magnet pole piece. Basically it has a slight taper. The butt plug fits into the backside (lmfao) perfectly but the end inside the coil is too small. I need to send it back (just the one piece) and get it trimmed. For that I had to order an "inside vernier". It was less than £4.
I built up the spider.
And then a gert big pile of stuff was all opened and sorted.
Ti coated spikes and threadserts.
Ti coated bolts and threadserts.
I then spent the rest of the afternoon yesterday making up cables. This is the Speakon plate and inside wire for the sub.
Minto tbh. And this is the outside cable from the amp into the socket.
I also found my mini router and ordered this.
Oh and the wood has arrived. So when the sharpies I ordered arrive tomorrow I need to start labelling the countless pieces.
Oh and hmmblah...
After two days of looking at things like that that were apparently crap and fell to bits I finally found a more substantial one for use with the Forstner bits.
Oh and hmmblah...
Very nice, should make things a little easier and more accurate. Nice job on the cables too, they look great.
OK so as you may have noticed it is hot. Like very, very hot. That slows me down quite a bit. I didn't realise that the reason why the work bench I got for £18 was so cheap until it arrived. It was in pretty much every piece it could be. This combined with worthless instructions had me taking it apart several times to correct mistakes. However, I got there in the end. Sadly I could not find any bolts long enough in M5 or M6, so I used some left over from my CNC machine with wing nuts. It'll do tbh.
So that is now ready to use. I've also been mapping out plans onto the various pieces of wood which takes more time than working on them. I now have two of these, though. Just a few cuts with the jigsaw and then attempt to use the trimmer (don't worry I have two spares of these pieces lmao) and they will be done. The nastiest part is done (the burning stinky hole saw).
So yeah, just joining the dots now really. I also decided not to use the yellow odds 'n sods RCA cables for the sub etc. I got this for £43, and will use one out of the wall into the DSP and one from there into the Cyrus. Oh, and talking of the DSP I got that fired up last night on an old router PSU and had a tinker. It's a fantastic piece of kit.
They are Chord Co. But, the sensible option and certainly not because I will hear the difference /rolls eyes.
So aye, on the jigsaw tomorrow etc. Sunday I will start assembling the cabinet itself.
OK so got some done today. First up was the piece that the acrylic window panel will sit on. One corner needs some filing and it seems I lost mine, so I will do that when it arrives then paint.
This is the brace. Roundover worked lovely. Again, sanded this and got it almost ready. Just need to file off the burn marks from the hole saw lol.
OK so finally feels like I am starting to get somewhere ! Before I go into that though I forgot to mention I grabbed this on PD for £21.
I have a 5 way, but I am continually messing around pulling things in and out of it. I have flipped the "ears" and it will power the amp and all my chargers. Obs no protection, so another PD deal was this for £7.
OK so today I curved one edge of the port and then double curved the air end. I then got into my groove painting sealer. In fact I got so into it that only one panel is left to seal on the inside now. I literally ran out of space to put them to dry lol.
And said port. Sadly the filler is lost and it is too hot to go out to the front shed and look. So I ordered some more.
I have one outer panel to round over now. I wasn't sure if it would go into the sunken screw holes so did not want to risk it. By the time I figured it wasn't all the tools were cleaned and put away so I will do that tomorrow.
OK so today I did the part I was dreading the most. First I mapped out the bolt holes for the acrylic, then centre punched. This was after clamping it to the part it will bolt onto.
About two hours later. Took a bit to work out how much epoxy I should use on the threadserts. By the time I was done my hands were all sticky and I was annoyed lol.
I will do the gasket tonight, as I need to know how thick it all is with the gasket in before I set the wood part into the cabinet.
So today I finished the roundovers. I then attached the port and the brace. These clamps are fantastic.
And then started primer.
Fill, sand, fill again, sand some more and then the first coat of satin white. Still some sanding to do on the second round.
Sadly my skin condition is back with a vengeance. Which really sucks and is slowing me down badly :(
OK so no post yesterday. No point I was just doing even more sodding painting !. So I got the toilet finished lmao. OK, dad joke but it does look like a bog a bit.
Doubt it would hold my weight though lol.
But yeah, I seriously misunderestimated (lmfao, good old George Bush) how much sodding painting was going to be involved tbh. So, today I took myself and a load of panels out into the garden and just went at it. One more to do, but, not until the whole rest of the cabinet is built so at least on Sunday when I go back at it I can actually do something other than ruddy painting !
I also got this done last night.
OK so a quick update. My groin area became really bad again. It was peeling and bleeding. I went to the hospital and they did a biopsy. It came back as a fungal infection. Thing is, the initial infection I had was very misleading and thus why I am still here in pain 4 months later. I am hoping I can finally rid myself of it. It has been no fun whatsoever and pretty damn agonising.
I swear once you turn 50 you just start to fall apart. Any way, I bought a new cheapo cordless drill with two batteries as I killed my Bosch screwdriver. Not my Bosch Pro drill, just the screwdriver tool. It just doesn't have enough torque. Any way, yeah, that should help and stop me having to continually switch out bits which is annoying and very time consuming.
I also got this.
And have had an idea of a very small enclosure that should look good too.
OK, so finally I am not in agony. I fitted the gasket foam and bolted down the top.
And then set to work.
So the top and back are now on.
I have to wait until tomorrow before a side can go on (and the bottom) as firstly I need to finish painting the inside of the port and secondly I need some stanley blades to scrape the paint from the edges. It will literally stop it screwing together properly.
I did this last time but was in so much pain after I did not get a pic. But the feet threadserts were set with epoxy.
And so.
OK so I am now waiting for paint to dry. The final side is in primer, so now needs two coats of satin white. Not sure there will be enough time today to get it all done but we will see. Just depends how it dries.
I have now fitted the bottom. So, this will be the last and only fully cross sectional pic.
Front.
And the back.
Now you'll note there are a load of holes and markings there..
That is because this is done.
Which I am very happy with. I also ordered this. It is not the usual material (which turns to powder and cracks if you drill it) it is PVC. The reason for that is because this will be the back box for the VU meter. I will machine my own face plate for it in gold.
It will need two speaker terminals (got, I got them before I decided to switch to Speakon) and a power socket. Will sort that out later.
Well for a moment there I thought it was over. I laid it down and placed the side panel over it. It was out. Like, I would say nearly a centimetre out. I sat there wondering how I could have gone so wrong. Then I remembered this actually happened last time. To fix it you line it up at the top (I put two screws in) and then pull the bugger into shape and add screws as you do so. The back was the most off, then the bottom, then the whole front unit with the port on. I got there eventually after drilling out the motherlode of countersunk holes then pre drill etc.
It is about 1/2mm proud along the front. That is fine, it will sand out. I think that blade thickness comes into things when you are talking about .mm.
I then spent the next hour or so setting this up.
