Saphire 290 Tri-X 1230/1550 & 2500k @ 4.00ghz
EDIT: I seem to be losing points on the 14.1 drivers because I got 2573 with 1190/1550 on 13.12 and that was with my CPU at stock.
14.1 is not much use for benching, if you are not going to use Mantle try going back to 13.12 for gaming or 13.11 for benching.
Here is my 290X doing the same clocks, if you add on 10% to your score for the difference between a 290P and 290X and also I am using the better drivers 13.12 then your score looks about right.
What speed were you running your CPU at as it can effect the scores even with a single card.
I'll give 13.12 a go tomorrow if I feel up to it, I should be able to squeeze a few extra points out.
I'm only running 4ghz on my CPU, from stock to 4ghz I got around 40-50 extra points IIRC I might try to get 4.5ghz when I try the 13.12 again to see if I can get even more of a bump in points.
Just tried valley with the same GPU clocks as before but with the CPU @4.0 instead of 4.7
CPU 4.0 scored 3048
CPU 4.7 scored 3062
Latest score
3930K @ 4.37GHz
2x GTX 780's at 1.12GHz
32GB RAM @ 1666MHz
4,777 is the highest score I've had yet. Previously my best was 4,400 before I OC'd my GTX 780's. I recently put my GTX 780's waterblocks on so they run about 45c max now even at 1.12GHz which is a big OC considering at stock they run at about 860MHz Baseline / 900MHz with GPU Boost 2.0. ^_^
Just beat my score again, my CPU is holding me back can't get any better.
1200\1600 GPU and 4.7ghz CPU.
Loving your temperature![]()
