AlienALX
Well-known member
So, I got some more done. So for update 40 here goes....
The tile cutter is no good. The blade is far too thick and the bed isn't big enough. I will give that to my brother. Instead I went and got out my old 20mm diamond coated blade. I then used Gareth's Dremel until it literally stopped dead. The battery goes like instantly. So I put that blade in my cacky one and finished the cut.
I need to machine more white supports. Will do that tomorrow. What I didn't say was that basically every front and rear join is getting a cover panel. But these will serve two functions. One, to get rid of any crap edges and saw marks but also to act as a channel for the top to drop into.
Those are 20mm high by 297 wide. So the whole width of the case. 15mm will be joined to the front (top and bottom edges) with 5mm overhang (none on the fixed bottom obs 'cause it's already there). They read from My Iron Lung, top to bottom (one verse).
I ordered an A4 for this about 6 days back. Was less than £5.
