AlienALX
Well-known member
Update Nine - It started out fun....
So tonight's mission was to get the rads both in and the fans connected. First thing I did was cut off all of the RGB wires.
I then realised that the top of the case does not have through holes for the rad. They are threaded holes. I guess this makes it easy to screw an AIO into. However, no good for me. So I took it all apart and drilled them to 4.5mm.
I then messed up the fan orientation about four times, and finally got it in. Only to realise the stop plugs were on the wrong side. So it all had to come out yet again.
Got that in, turned the case over and started fitting things. After about 30 mins of head scratching I realised the holes for the two fans do not conform to a radiator. They are too far apart. Take whole case apart again, up the fan orientation three times and then finally.
OK so the rads were now in with the fans on. Which was nice. I did, however, have to change something. Cougar put a 92mm fan in the back there but with it in I do not have any clearance to make the plates fit that will hold this in (see next pic). So, I dug out a NOS Antec clear fan, removed all of the LEDs and put that in (it's 80mm, leaving me the clearance I need) and fitted that. Oddly they give you a 80mm mesh dust filter but not a 92? odd.
That is about where it will end up. I also connected up the CNC, installed all of the drivers and etc and gave it a "hello world" with the PC sending the data.
https://www.youtube.com/watch?v=JrpiDzgFvdg&ab_channel=MyMidschoolLife
All seems to be doing what it should and it didn't blow up, so there's that....
Well, aside from the hour of troubleshooting because it refused to connect and me then realising that, you know? you need to actually turn it on.....
