Dicehunter
Resident Newb
So I couldn't help myself, I saw the 3080 Ti HOF and had to get it for my monochromatic build, Few things to add like another 2 sticks of the same memory and possibly a white support bracket, I may swap out the
The card itself is 1 of the heaviest GPU's I've ever come across, Must be in the region of 3-4KG, Great performer though, Very quiet and cool, Boosts up to 1950 on the core on its own and settles around 1920 after 30 minutes of a valley run.
Specs of system -
All fan stickers removed and replaced with white vinyl -
Capellix pump top replaced with custom OC3D plexi top -
The removable plate to the right of the motherboard now has a white/red vinyl cover to try and match the orientation of the custom Cablemod 24 pin and triple 8 pin colours -
Finished shot -
Corsair H115i Pro XT for a Corsair H115i Capellix as I really prefer the look and then use the former in my HTPC, But it's largely done
Specs of system -
AMD Ryzen 5800X 8 core 16 thread
Asus ROG Crosshair VIII Hero X570
Corsair Vengeance RGB Pro 16GB 3600MHz *2x8GB*
KFA2 RTX 3080 Ti HOF - 12GB GDDR6X
Western Digital SN850 PCI-E 4.0 1TB + Heatsink
Western Digital Black 6TB x 2
Corsair H115i Pro XT + 2 x Corsair HDRGB 140mm
Corsair RMi 1000 Watt + CableMod Cable Replacement Kit
Corsair 680X Tempered Glass Black + 4 x Corsair Crystal RGB Fans 120/140mm
I had to remove the bottom and middle fan on the front of the Corsair 680X as there was simply no room, A shame really as the Corsair HDRGB fans on the front looked great, I'll have to see what type of super slim fans I can get for the front to blow a little cool air over the card.... or just get a bigger case.
UPDATE
This eventually turned into a red/white/black themed OC3D style rig with case changed to a 5000D Airflow and cooler swapped out for an H150i Elite Capellix.
Front HDD cavity of the 5000D sealed off with plasticard and vinyl -
UPDATE
Finished shot -
