What are those sandwiched acryllic water pipes called?
chris_86
I've searched high and low for something that seemingly has no name. You know those amazing builds by enthusiast builders that have those bits on the bottom or sides that are basically two bits of acryllic or plastic of some kind sandwiched together, and water flows through the middle in patterns, lines etc, and there are o-rings creating a seal?
I've tried the following search terms:
  • custom water channel
  • custom monoblock
  • integrated reservoir
  • fluid flow tracks
  • etc
and nothing comes up that's helpful. What I'm getting at is like custom monoblocks but on the base of the case for example, see image below, and they just look incredible. If you look at some of the real enthusiast builds you will see what I'm getting at.
If any of you know what it's called, please shout, and then I can find out how to make one for my 2019 build :)
Those are done custom and are not a "stock" item, contact Parvum and they will be able to price you up what ever you want.
Well, you've solved the puzzle. Many, many thanks. I've been on the Parvum website and I'm dumbfounded. Those cases are incredible and good to hear they're bringing in tempered glass for the windows too. Haven't a problem with acryllic cases as long as they're good and those are stunning. The months of planning are going to be as fun, if not more so, than the actual finsihed piece :)
