Network Card issue - Mellanox ConnectX-3
hello,
i bought two 10GBe mellanox connectx-3 cards to direct connect two systems.
everything (seem) to went fine.
windows installed drivers and in 10 minutes i had setup a 10gbe network.
until a day later.
macrium reflect was making an automatic backup and i was informed that the verify ended with a hash error.
i run the backup again.. same result: hash error.
i then did a file copy with verify (using totalcommander).
i copied ~3000 jpg and tif files to the second system.
totalcommander nearly immediately warned me that some of the written files are different.
and indeed when checking the files they showed artefacts or only half of the file was displayed, the bottom parts of the images were only artefacts.
i was pretty shocked that the file transfers, seemingly, went fine when not veryfing.
but around 5% of the files where destroyed after copying.
had i not used macrium reflect and verified the backup image, i would not have noticed it that early.
i did a bunch of tests to figure out what the culprit is (cards, cable, harddsik etc.).
i don´t want to bore you with that.
in the end i noticed that when i put the card in the lower PCIe slot (the long one at the bottom called 4_3) of my asus crosshair 7 the network card produces these errors. files send from this system to the other system (no matter if the second system uses the internal intel 1GB via switch or direct connection to the mellanox 10GB network card) are probably defective.
when i put the networkcard into the second 16x slot, beneath the graphic card, the files are transfered without issues.
i have only one graphic card in this system, no other PCIe devices.
what can cause this?
someone with similiar experiences?
hello,
until a day later.
