Look what arrived today!
As soon as I got chance after work, I set out to start plumbing in some stuff. Screwed in the motherboard into my case, then set about installing the CPU waterblock.
First time doing any of this, & what I will say, is the XSPC for the 1150 sockets are a wee bit fiddly. The post idea that's used on the 2011 sockets seemed a great idea ( its how my head bolts are on my car ) as that aligns as soon as you lower the waterblock.
But no, the screws wont go through the motherboard as the holes are too small, so ended up with having to put the waterblock on the CPU on first, & then carefully putting the other screws through the waterblock, through the motherboard so it could "bite" into the backplate.
so first step was adding the thermal paste to the CPU ( this looks right amount yes? )
then carefully screwing up the tension bolts & ended up with something like this
routed in the Blue LED's & put in the compression fittings from Monsoon
and with my 240 rad painted & fully dry....
put in the PSU from Super Flower & test fitted the rad. Still waiting on the fans from Overclockers, nearly a month on. May just cancel them & get something else. That order is also stopping me getting the coolant.....
Whilst going through my PSU, one thing TTL DID NOT MENTION
( and im so annoyed about this from Super Flower ) is this:
What is this! WHAT IS THIS RUBBISH! How am I meant to switch on my PSU without a powercable?!! DO I look American? Did I Order it from America? No I didn't.
Nor did it state it in the description that the powercable was of Alien design. Now I know some of you will say I can just buy another powercable, but its not the point is it. That's like sending a U.S citizen a UK plug.
Ill update the thread when I get more goodies. Quick question though, im thinking of ditching the Corsair AF120 1500RPM white LED fans for the white 120mm Aerocool DS Edition Fan.
What you guys think? Stats show they shift more air at a quieter noise level
from these
to these...
I think they may look really good spinning up too.....? :huh:
