Black Magic
Ok thanks. Got a link, or just google them?
I've had not one single leak from any Bitspower or XSPC compression fittings. I have a few Bitspower 45s, 90s, rotaries, etc, and NONE of them leak. You can buy those rotaries with confidence about leaks. I even bought a crazy one that rotates in 3 different spots and it was leak free.Ok, with half the month over with, next thing i need advice or help on is connections. Bitspower look really nice, albeit a tad expensive, but unsure wheres best to look for conections for my loop.
2 things im certain on, is colour. I either want white, to go with my white case & Rad, or, black chrome. But, as allways, im open to suggestions. Also on a side note, are swivel ones worth having, or are they prone to leakage? Reason i ask, is they might make installation of my tubing that little bit easier, but not at the expense of a swimming pool if its advised to stay clear![]()
Im in for a shock, as im crapping myself, going into the deepend with my first ever watercooling rig....
.... Id pay someone to do it, but there is no one over here that will touch it, or is confident in doing it![]()
