Guys,
Please help if you can with some wiring advise ... the decription below is based on me looking at the inside of the Mach II base with the front cover on my left and the back panel on my right.
I am trying to help a mate with his newly aquired Mach II with two wires that have come loose. On the top of the ChipCon control board immediately behind the power socket is a white connector block where four wires should connect upwards at a 45degree angle to the block (blue brown blue brown). This is how it is on my GT so this should be same, however, the second blue and brown are hanging loose
I cannot see how to get the wires into the block since it is really fiddly in there, it looks like just slots for the wires and two smaller empty slots just above where the each wire goes, and there is also a black smartie tube looking thing in the way of it connected to the compressor. This black tube is on a bracket I do not know how to disconnect either. Any ideas on how I connect up the wires and maybe move the black smartie tube thing out the way so I can get near the white connector block?
