name='PV5150' said:I never believe the Enquirer![]()
name='{TAS}Lone Shadow Wolf' said:so after all these discussions which card should i be purchasing???????![]()
Austin said:lol, you have enough money to buy an x850xt pe now and then buy a g70 or r520 later without having to sell anything!
i suggest get an x850xt pe, if you want i'll direct you to one on msn..
{TAS}Lone Shadow Wolf said:ok kool is the 850xt just as easy to install?
and could u suggest THE BEST MOTHERBOARD austin suggested the LANPARTY UT nF4 SLI-D i just wanna know tht everything will fit together when i get he cpu x2!!
plus would u recommened type of ram !!!!! as well
thanx 4 the help guys!!![]()
name='Dave' said:the x850pe wd be just as easy to install as any other agp card....but now you are talking about pcie....how are these to install anyone.. same as agp??
name='{TAS}Lone Shadow Wolf' said:pcie so it is a bit different to install from the 6800?
{TAS}Lone Shadow Wolf said:ummm i might wait a bit till i can get my hands on the x2 !!
but u can give me some recommendations for a good MOBO! the only shop tht sells wholesale parts here is: http://www.tasmanianpc.com.au/
{TAS}Lone Shadow Wolf said:i no dude so wat should i do
i dont have a clue bout what mobo i should get ?????
{TAS}Lone Shadow Wolf said:k i found one http://www.mittoni.com.au/catalog/product_info.php?currency=AUD&products_id=1884
but should i get tht THEn the X2 or the x2 then the lanparty motherboard????
and tht mobo looks like a real bitch to actually install i havent got a clue on how to do tht!!![]()
