Watercooling a Stacker???
I've measured up the bottom of my stacker and it looks like you could easily mount a 120.3 in th bottom, althought hte pump might have to be external if you do so.
yeah, i figured it out now, i had two akasa ambers in the spare psu mount so i thought it wouldnt fit in, i'm gonna put the pump in the drive bay supports. what do you think the best res for this would be, i'm thinkiing dual bayres. dunno
yeah, methinks thats the best route too, the danger den one?
phils taken all of the bayres's off of the website, so i've asked him to see if he can get a danger den dual in.
it fitted in even with the ambers in place, what a fool i am
i need recomendations of fans, cant be more than 30db, and must be obtainable easy from the uk. preferably by phil
Who's 30dB are you talking about when you say that? Fan specs vary quite a lot, so is often better to state what fan you want it quieter than than to just say a noise level.
G
Hello ppl, just joined. I will be getting a MachII GT very soon
However I thought I'd give a little imput here to see if I can help lol.
I Have a stacker with a 120.3 rad and a DD12V Pump on the floor of the case
Here are some pics of the build process:
Sorry i'm a little late. hope I helped.
very nice mate, almost exactly what im doing, how have you put it on the bottom, ie, is it dremeled, and what is the silver thing around the rad
Yup i dremmeled the original hope to make it a little longer and drilled new holes to screw the rad down. That chrome surface is standard on these rads. Its an XSPC R120-T Crossflow Rad :
No Problems mate here are my Sys Specs:
CPU : P4 560J 3.6ghz
COOLING : Custom DD H20 Cooling
M/B : DFI Lanparty 875P-T
MEMORY : 1gb Geil Platinum PC4400
PSU : OCZ Powerstream 600W
GFX CARD : BFG 6800GT OC inc. NV5 Silencer
CASE : Modded CM Stacker inc. Window
CPU Speed O/C : 4.41Ghz (Prime95 Stable) / 4.52Ghz (1-2Hours Stable)
GFX Speed O/C : Core @ 445 / Mem @ 1200
CPU temps : 28-32c Idle / 39-45c Load
Case Temp : 23c
Memory Timings : 2.5-4-4-8
Super PI Score : 27sec (1MB)
AquaMark3 Score : 80,649
**EDIT** Sorry, the fans are 120mm YS-Techs (125CFM)
