Vista Version Comparison
name='Phnom_Penh' said:
Why? they don't check to see whether you have it installed, you just need to insert your windows disk at the beginning of the upgrade... ;)
Never taken the upgrade path before to be honest. Always assumed that you needed a fully operational licensed version of the previous op sys installed before you could upgrade.
If all you need to do is pop the disk in, then that sounds like a winner :p
