What an absolute nightmare. Hory shet.
I started at around 7pm. Might have even been earlier. Looped up the rig.
The first thing I realised was that there was a capacitor on the new board right in the way of the pump outlet fitting. Because the pump top is quite big this meant I could not fit it how I had originally test fitted it.
I tried the pump every single way, but with the port coming out straight the glass would never fit back on and with it on the right it runs into the front IO board. TBH? this is a stupid mistake by Antec, and one I am really peed off about. I could not even relocate the pump, because there is literally one place you can put it. In the end I cannibalised some Corsair standoffs that come with an AIO and this brought the pump out away from the mobo tray enough so that the fitting cleared in the original position. At this point I looped it.
Then I realised I had made another mistake. The pump to SATA cable I bought (EK) is 12v only. God, what a racket. That's OK though, I can sort that out later. Ran the loop for about two hours with the hardware turned off. Noticed I had a leak. Guess what it was? yup, a straight rotary AGAIN. Managed to replace that with a straight extension (didn't matter because the fitting that goes into it is rotary) and tried again. Noticed another leak. This time... You guessed it ! exactly the same type of straight rotary. Only this time I had no replacement.
Thankfully it is the one going from the flow meter into the pump, and there is nothing under it. Plus it's a tiny drip. So then I powered on the rig. Nothing. NADA. Fans going absolutely crazy, no POST. Now at this point I shat myself. Like, totally shat myself, and figured I had bricked the GPU somehow which at this point in time would be irreplaceable. However, I noticed that the RAM RGB was not working. At which point I realised I had seen this before. Once I over tightened the clamp pressure on a CPU block and saw the same symptoms. So, I took the board out after draining it and added springs to the back as I should have done originally. Bingo bongo, it boots.
However. Now I have other issues. Firstly one of the RGB connectors on the hub has snapped (they really are the worst headers I have ever encountered) so the pull fans on the rear won't light up. This isn't a major issue as there is another header, however it means I need to completely remove them all as one of the daisy chains has pulled out also FFS.
So I have ordered some more bits. Firstly to completely remove the sh@tty straight rotary and fit something that won't friggin leak. I also get a free drain port, which I will no doubt need.
Bitspower one was out of stock. Plus it was 3x as much as that. I've ordered this to create a 7v feed to the pump. I really can't be assed paying AC for their software every year and fitting an enormous controller just to run the pump at 7v.
And these. Because the ones that came on it all fell off and have trashed the top of my pedestal.
OK. So the final problem. Because I had to space the pump away from the mobo tray the glass no longer effing fits. Seriously, you couldn't make it up. So I have ordered these.
I will show what they are for when they are fitted. No point trying to explain it.
