dipzy
Slot options > 'max-packet-size' : 'small'
So the name would be: Max-packet size
and value would be: small
never done this before
never done this before![]()
Lower case 'm' though.
Just done this for my SMP client. Out of curiosity, if I was to get rid of the SMP slot, and re add the small wu flag thing, would I get a small WU instantly? Or does it need to get a fresh WU from the servers @ stanford?
I stayed over my girlfriends last night which is always a nice opportunity to run the rig full whack all night without it being interrupted, and i come home this morning thinking id have done a good solid nights work and the F@H client is not running nor is afterburner which i use to monitor my gpu usage
Im one very unhappy folder today![]()
I have been running into a lot of problems folding. First a big storm comes through and blows out the power for 2 and half days. Then my UPS is having issue which I have not taken the computer off it. I tired to update the BIOS and that blow up the machine, took me awhile to recover from that. Just one thing after another. Good thing is that the kids are gone for the weekend so I hope to make up some ground.
Matt
Matt
That's really unfortunate. Hope you get everything sorted![]()
Things are starting to get stable now. My one computer keeps turning off for no reason. I am not sure if it is over heating or what. I do have it overclocked I might turn it down to see what happens.
Matt
What are the temperatures?
I looked at the temps and they seemed fine. Might have something to do with the overclock since I overclocked as high I could with not changing the voltage.
Matt
Had the same issue with bubbles screensaver,but no problems with the W7 logo.I know i'm fantastically out of my depth here, but by any chance do you have a screen saver set on the rig which keeps turning off? I was having issues where I would turn the screen on (i turn it off when not in use) and find that i'd been logged out - the PC had restarted itself. This only started to happen since I had set a screen saver (the bubbles one) and the problem seems to have fixed itself now i've removed it.
Just a thought![]()
A few times now, like this morning when I checked on it. It looked like it rebooted and was back at the login screen. What would make a machine reboot?Yeh you might need to up the vcore slightly. Do you get a BSOD or does it just simply turn off?
