The latest HFM.net now supports V7 as well as V6 and it is supposed to correct in PPD calculations
Awesome, hadn't heard this yet. Thanks for the heads up.
Are you using the V7 client?
I have noticed some strange fluctuations with that, but it seems more down to the estimation calculations rather than computation actually slowing down on the work unit.
On the other hand it could be a background application/process eating away a few % of cpu time which can badly dent PPD.
I found when running FAH on my Q6600 @ 3.2-3.4 ghz having Hardware monior running in the background took as much as 1000 PPD away from me while using 0 to 1% of CPU time (as seen in task manager). When getting between 8k and 10k PPD, 1000 PPD is quite a chunk to lose for an application seemingly doing nothing.
i'm using Gpu Tracker v2. It seems to have fixed itself now, currently at 19,946
I assume you arn't folding on the GPU at the same time.
These 609x work units arn't giving me the highest PPD ever but they are pretty consistent so I'm pretty happy folding them.
14k PPD on my dual quads and 28k PPD on my 2600k while not GPU folding and 12.5k & 25.5K with GPU folding (all according to GPU Tracker that is).
Out of intrest. What speed is your CPU running at?
I have half a mind of replacing the 460 in my folding rig. If that does happen I will probably put my 460 in the spare hardware thread.
That could happen quite a while from now, but if/when it does and you havn't found a replacement for the x800 I will hit you with a PM.
My CPU is running at 4Ghz, right now ppd is 21,163 which is what i had before in the morning when i started the WU and before all the fluctuations.
my dedicated f@h rig, which i've got all parts for, just require a GPU but i'm in no rush to build it, just something im doing as it happens![]()
Maybe you could put a request in the spare hardware thread.
Even if its a GPU you cant fold on, just to get the CPU up and running untill you have a GPU to fold on.
My rebuild is taking longer than planned as my motherboard (UD9) seems to have decided it's not happy overclocked, or stock, and likes to run @ 98c.. I wonder what I did to it.. :/
A quick question guys, how do I know when a WU starts earning bonus points?
