Project Insomniac
nice camo scheme, loving it. May i ask what are you doing with front-top of the case?
^^^ that i mean
Cheers Sockey :D - i had half a day to spare before work so i decided to brace up the the case using the original side panel (the panels did'nt take a tumble down the stairs) so i cut it to shape and painted it along with the rad and silentmax Hdd caddy i'll be using -
And the finished job with and without flash - still hard to catch the feel of it on film lol !
Wow.. I have to say that looks amazing!!
You can paint my case anyday... (not my new one, since thats acrylic)
Cheers Teknokid - i've seen your project and its sweet duder :D Would paint your stuff anytime but then it would be a waste of acrylic !!
Weekends are crazy busy for me but here goes with a mock camo parts build up to give an idea of how it might look !
name='Mr. Smith' said:
Gotta be honest - wtf have you done!!!
haha... took the words right out of my mouth
But i carried on to page 3 and its started to grow on me! i acctually like it and i love the way you done the rads good job mate... btw where di you get the the cans from? any chance of a pic so i know what kind of cans were used
cheers mate
making the most out of a bad situation very nice
Did'nt get anything done last week as it was my birthday and i was mostly drunk or hungover lol !
Not far off building now - a few things still to get and i cut some mesh and sprayed a few more bits for the case this am so a minor update !!
Specs for the build as follows :-
Qx9650 (w/cooled)
Dfi X48 mobo
4gb OCZ Pc8000 reaper
EVGA Gx2 (w/cooled)
74gb raptor
Corsair Tx750w Psu
External optical drive
Got a bit more done this morning before work !!
Stripping down thw Gx2 you'll need a Jewellers Phillips/crossdrive screwdriver !
After some carefull dismantling and reassembley you'll get to this !
I cant remember who 1st cut the outer casing to fit over the waterblock but i figured if i was going to void the warranty by doing so i might as well go the whole hog and do this !
This is like the Konigsegg for me. It doesn't look quite right but its still f'king cool.
Well done after your mishap its brilliant.
