The position may be altered slightly depending on the routing of tubing but you get the general idea.
Custom made dual DDC pump bracket:
Pumps mounted with XSPC reservoirs:
The pumps will be mounted with rubber noise dampening mounts as even though the DDC's are not loud they can give off noise through vibration:
