OC3D GTX 1070/80 Owners Club
Thanks!
Well this is not the final build, this is just an impatient I must play now and experiment build.
Using a single 420 (3x140mm)
under heavy load the CPU will bounce around 60C and GPU in the low to mid 50's
When I get setup in the Caselabs SMA8 with a 560(4x140mm) + 280(2x140) on the GPU loop, I hope to see high 40's, and close to ambient on the SLI 1080Ti's (Yes I said it SLI 1080Ti's, you know it's coming, don't jinx it!)
Overall, I'm pretty darn happy with this config.
I posted more details in the "Show Us You Rig" Thread:
http://forum.overclock3d.net/showthread.php?t=76843
EDIT:
The features of this board are glorious! It's whisper quite, like I faintly hear the hum of the D5 pump at idle, fans at ~600RPM. under load, it bounces up and down based on the custom fan/pump curve I made monitoring the GPU/CPU temps. It looks uber sexiness too!
It makes me feel like a winner :)
On the topic of the 1080 Ti's, I have a sneaky feeling they will have the same amount of CUDA cores as the last gen Titan X, 3072.
PC Specs:
ASUS Maximus Formula VI
Intel i7 4770K @ 4.8 GHz CPU
EVGA GTX 1080 GAMING ACX 3.0
XSPC Full Cover Razor Waterblocks
Corsair HX1000i
Samsung 840 EVO 500 GB
I am very happy with the XSPC waterblocks, temp on the hottest card is 38-40C full load @20C ambient with fans on low.
