OC3D GTX 1070/80 Owners Club
Guaranteed to give TTL a visual crisis.:D
There is not much right about my 1080 PC, the colours don't match and the layout is awful but I don't care.:D:)
This entire colour and the weird layout just totally focked with my brain :huh:
Good god man, I am never coming to you for colour coordination tips ^_^
Haha I'm so with you on that one Dicey!
I feel I need to slap you with a soggy fish for this sin against uniformity :p
Haha! :lol:
Wait, the nVidia bridge is out?
Ohh wait, hold on.... First time barnsley is surprised :p
PC Specs:
ASUS X99-A II m/b
Intel i7 5930K @ 4.0 GHz CPU
Corsair Vengeance DDR4 2400 MHz CL14 4x4GB RAM
MSI GTX 1080 Founder's Edition
Corsair AX860i PSU
Fractal Design Define R5 case
Samsung 850 Pro 512 GB SSD
Samsung SM951 128 GB SSD
2 x WD Red 1 GB HDD
I can say that I'm pleased there is hardly any coil whine even at 250 fps in some games, with the exception of Elite: Dangerous it will coil whine slightly at 120+ FPS becoming noticeable around 250. Not sure why it only happens with this game, seems Elite just likes to bust some balls :D
Finally got a pic -
Now that is what I call an all black out build! Nice one Dicey! I love it! :)
I like how the top front fan is like squeezed in between the H100i and the front ^_^
And I see you've used mostly all "OEM" fans... No rubber grommets corners or so :p
All Corsair white LED fans ^_^
There's actually about 4mm of space between the top front fan and the H110i GT but the pic doesn't show it very well.
Hey all,
As an interim option prior to doing my complete new build - likely in the autumn now, as I don't really game so much if the sun is shining - I picked up a Palit GameRock GTX 1070.
The 1070 is running in an older rig:
2600k @ 4.4ghz
Gigabyte Z68X-UD7-B3 Motherboard
32gb DDR3 1600
2x Samsung EVO 850's RAID0 (new)
Corsair HX750 PSU
W10 Pro
I've been fairly impressed with this card out of the box, it's fairly large but that's due to its excessive cooling. I'm yet to see it go above 69c during benchmarking, that's with it boosting to ~1900mhz and fans remaining below 50% - ambient temp was low 30's during this testing.
Anyway, as the card had been performing so well untouched, I thought I'd have a tinker at overclocking. This GPU is marketed as an overclocker, with 8 phase power, OTT cooling and supplied OC software - that's based, like so many are, on RivaTuner.
My initial tinkering involved just setting GPU Core Offsets, no Power or Voltage tweaking. Seem +100 on Core = 25/30 actual Mhz increase, however card does start reporting being "Pwr" limited (GPUz) so I popped the Power Target up to 110% (114% seems limit in tool) and that seemed to help.
Doing this, I got up to 2ghz fairly easily, temps still not going over 69c. I pushed a little further to 2025mhz but ran into some slight instabilities - not unexpected. So, I thought I'd add 2% to the GPU vCore and re-test. Same result. 5% on vCore. Same result again.
Double checking, it appears that my vCore increases do NOT actually make any changes, my 1070 always shows 1.065v peek under heavy load, no more irrespective of the voltage increase % I set. Seems it's LOCKED on a card marketed as an overclocker...surprising.
To be clear, I'm using the official Palit OC "ThunderMaster" and the voltage slider is of course enabled and can be moved, but has no actual on card effect.
I've just downloaded MSI Afterburner 4.3.0 beta 4 and will try that later.
Anyway, just thought I'd share :)
Scoob.
Hey all,
2600k @ 4.4ghz
32gb DDR3 1600
Corsair HX750 PSU
W10 Pro
Scoob.
When you are able to put a picture up so I can add it to the owners list :)
EVGA FE 1080 with an EK block, got the card when they first came out block as soon as they were available here in Canada. Walked in and bought at a retail store weekend of the 27th.
Got one of the first MSI GTX 1080 Seahawk EK X
Fresh out of the package:
And the System: (Currently holding #1, [Inetl i7-6850 and single GPU], on 3D Mark FireStrike & FireStrike Extreme Since July 22nd)
Debating redoing a couple legs on the loop when I color the coolant...
EDIT:
I don't have any overclock videos to post, but I've gotten it stable at 2164MHz settling around 2152MHz Core & + 590MHz on the Memory.
I run it 2139MHz Core + 525MHz Memory just cause it makes me nervous to push so hard.
EDIT:
Added to the list :)
Nice, was thinking about this same card, what temps are you hitting?? Ho much rad space do you use???
Thanks!
Well this is not the final build, this is just an impatient I must play now and experiment build.
Using a single 420 (3x140mm)
under heavy load the CPU will bounce around 60C and GPU in the low to mid 50's
When I get setup in the Caselabs SMA8 with a 560(4x140mm) + 280(2x140) on the GPU loop, I hope to see high 40's, and close to ambient on the SLI 1080Ti's (Yes I said it SLI 1080Ti's, you know it's coming, don't jinx it!)
Overall, I'm pretty darn happy with this config.
I posted more details in the "Show Us You Rig" Thread:
http://forum.overclock3d.net/showthread.php?t=76843
EDIT:
The features of this board are glorious! It's whisper quite, like I faintly hear the hum of the D5 pump at idle, fans at ~600RPM. under load, it bounces up and down based on the custom fan/pump curve I made monitoring the GPU/CPU temps. It looks uber sexiness too!
It makes me feel like a winner :)
