would a h60 be enough to cool an OC 8 core ? my friend is thinking of going amd soon and i know he will ask me what i suggest to cool it witth
i noticed on some benches i was looking at today the AMD was cooled by H80 and the i7 by a H100.
It's more than enough
Due to me buying a 4+1 VRM motherboard I won't be able to clock any higher than 4.2ghz, the turbo clock for the 8350. Any higher and the VRMs over heat and throttle.
The H60 will be used with push pull fans, and you need to remember that a stock AMD cooler is enough to run the chip at a 4ghz turbo, so yeah it's more than enough
I cool(ed) mine with a seidon 120 and had no issues. If he wants to go air I'd reccomend at the very least a bequiet! Dark Rock 2. People have used H100is in the past to hit the 'magical' 5ghz on 8350s.
I'm done with huge air coolers. Not that I don't think they're good because they are, but I hate not being able to upgrade your ram without taking it off or faffing around and so on. Oh and I don't miss scalping my knuckles trying to plug in the 8 pin EPS with my Noctua !
I do aim to overclock the 8320 but mostly just to turn it into the 8350 for less money. I'm aiming for the "work with all" 4.2ghz that most people run on their 3570k. I'm not looking for extreme clocks or anything that requires very expensive components or eats loads of power.
I will be benchmarking it
fairly against the Intel CPU that costs the same. Not the I5 3570k as that costs £171, and not the 3770k because that costs much more. I'm sick of seeing people comparing apples to lemons. Apples to apples !
I just looked and the Intel I5 3470 seems to be the most similar chip to my Xeon (which is a rebadged I5 2400 with more cache) so that will about do it, even though the Intel cost £143.59.
So it's still a little bit unfair, but not as unfair as comparing the 8320 with the I7 3770k and then all pointing and laughing. Nothing pisses me off more than people who do unfair unbalanced tests to make something look bad.
If the 8320 can topple my Xeon (and I'm pretty sure it will) then it will be a CPU worth having for price to performance.
