AlienALX
Well-known member
	So if you were here in 2015 you may remember the Pockit Rockit. If you don't? it was this.
	Jonsbo UMX1 with a Titan Black in it. I bought three for my main rig, but two was best. CPU was poo, a Pentium Anniversary. Any way, I sold off the Titan, put a Quadro in it and gave it to my aunt when my uncle was first diagnosed with cancer. She had gone without a PC for a long time, but now needed one.
And there it remained until Thursday last. When I got it back.
	I wanted to do a custom LAN rig that I can take to our lan night once a year (three days in a row). So cheap was in, but Pentium out. So I got this.
	Four cores four threads. The RAM in there was 4gb total, so that got replaced with 8gb Vengeance my pal sent me down last year. For the GPU? it is a 980Ti with a 1080Ti cooler on (long story).
This is what it looked like before.
	This is the plan.
	And so.
	So the first job was getting it all out (a nightmare) and fitting the new CPU. The cooler broke (plastic push pin crap) but it works.
	So the first thing to do was buy a huge handle. 9", that is what she said.
	In brushed stainless. The side window thing (Mayhem grille, was supposed to be meshed but the mesh was crap) is going in favour of this.
	So something like this for the side.
	The Mayhem one will be going under the fans in the bottom (this was a mod)
	Which I accidentally cut a cable relief hole in the wrong side of lmao. That was why I made the cover with silver Dinoc on. But when I removed that look what I got.
	Sometimes things were just meant to be.
OK, so first new mod. Cut down the IO PCB. The USB3 header on the board has a snapped pin (I did that way back then) and besides I don't want it in the way of the GPU like it was before.
	I will be CNC a front cover plate with some branding on.
Mod two, get rid of the puny whiny top fan and replace it with something with more grunt. Problem is you can't. The fan is 120mm alright, but the holes do not line up with the posts it slots onto. So after a lot of head scratching I drilled the fan screw holes bigger and now it fits.
	Next mod, handle.
	There is just one problem. Due to where the fan goes you need to move the handle back.
	*sigh*
So I needed a radius. That was easy.
	Convert into a full circle.
	Then use this bit of it.
	Machine out four pieces of 5mm, plastic weld and sand.
	And finally.
	That will be frenched onto the case and painted body colour.
Keeping things cheap this should be about all I need.
