High Pitched Noise From Loop
ZeroInfinity94
Hello....
Another problem,
So loop is together, clean, filled, bled and yesterday there was this high pitched noise that started, its like a squealy whiny sound, now when I pinch a tube it goes away and when the pump is off (of course) it shuts up.
Any ideas?
My initial suggestion would of been coil whine from the GPU but if squeezing the tubing stops it that's not it.
Loss seal on a fitting?
Not that I can see, checked all fittings multiple times and re tightened everything after cleaning with the Blitz kit from Mayhems also not seeing any kind of moisture out of the loop at any fitting or an seals on the blocks/pump+res.
It's there when the pump is on, and it's not there when the pump is off.
What do you think it is? :D You need to find a way to control the pump speed, and then find a speed where it is silent. It's probably running full speed. My D5 pump can go 5000rpm, i have it at 2000rpm.
I had a similar problem last year. What I would suggest you do, is that you take a sheet of A4 sized papir (from printer etc) and roll it together. Put it up to your ear and start pinpointing where the noise is coming from.
For me it was a Bitspower 90 degree angled adapter causing the whining in my loop, and replacing it fixed the whining. So it was probably a bad seal vibrating inside the adapter being caused by high flow pressure
My dual D5 setup had what sounded like a buzz to a whine. It was actually vibration. I put an extra mouse pad under the feet of the case, it would stop.
You haven't got it plugged into a corsair commander pro by any chance have you ?
I had some issues with the pump on my gpu aio, horrible squealing sounds, everybody said it was a airlock, but I dont have it any more since running the pump of my motherboard header.
I have worked out where the dammed noise is coming from and I think I know what it is....
The noise is from my CPU block and I reckon its because I am going from a 1/2" inlet down to a 3/8" outlet.
If its not this then probably gonna switch blocks and go with an EK block as the one I have now is a pretty cheap one from Liquid.Cool
the usual suspect(s) for high pitched noises in a water loop is bubbles (air pockets) in right angled fittings, or bubbles travelling through the pump, or air pockets in your block.
bottom-line = you probably have air in the loop somewhere.
FIX:
  1. completely fill your loop; even the res to its' max.
  2. remove anything that could move around in your rig from it.
  3. switch rig on (or just the pump).
  4. physically, hold the rig in the air with your hands and gently manoeuvre it in in as many directions as possible until the air pockets are shifted to the res. (do not shake your rig - as theis may cause micro-bubbles; which are harder to get rid of)
the noise should have stopped.
once all the noise has stopped (bubbles/pockets are eliminated, you can then bleed the res to your preferred level (if required)
i hope this helps. :D
