Hi evry1 any help on the following subject much appreciated. heres the problem: I have just purchased a samsung le26r74bdx TV however when i plug my laptop in with the VGA cabel (TV has vga input) the TV will not pick it up. However, if i plug a different laptop in and select PC from the list of inputs on the TV menu(this was previously greyed out and unselectable) it works perfectly, and i am able to select PC. I can then unplug the vga and put it back into my original laptop and the picture is perfect. However if i switch it back onto TV or Xbox i can no longer select PC unless i use the other laptop again. the display adapter is listed in device manager as "VIA/S3G unichrome pro IGP. I have been on to fujitsu siemens website(laptop manufacturer) and downloaded and reinstalled correct graphics card drivers. also checked samsung website there are no drivers for the TV.
