KingNosser
Well-known member
Well that just means a hardware fault, but given that it's happening across multiple mobos and cpu's i'm more inclined to think it's the nvme drive itself than anything else, does it have any cooling on it or thermal pad how old or new is it, these things can fail as much as they are better and no moving parts.
Idk if there is a way to test the stability of the drive, but first thing i'd check is a drive test on it's speed to make sure it's getting somewhere near where it should, plus if it crashes in that test then it is 100% the nvme drive, plenty of apps to check that like crystal etc.
problems like these can drive you a little crazy as it can be hard to pin them down, I had issues after the HBA card install but it wasn't related to the HBA card but the antivirus I was using at the time, these things are not always very obvious to track down and solve, but imho at this moment i think it's something with the drive as the rest you have been switching out etc.
