CPMFW
you're right mate not too long to goawesome mate wont be long then
have to let us know what that sound card is like as im looking to get one. i guess its the d2x version?
I'll let you know asap and yes it's the d2x version
 mainly looks and the digital featuresI've got pictures from the front IO cables Im making a post now
Just curious, what was the main reason you decided to switch from the AX750 to the 760i?
will do mate!i see. well do report back your experience with it.
will do mate... cheersLooking good CPMFW ! Keep it going
cheers mateThis looks fantastic, really, really good job with that modding. The white accents also look really good.
Keep it up!
matte black with white writingI would try black matte.
thanks for your input mate...id paint the whole thing one colour like white and then go over it with black. once its dry sand the letters down with some fine wet and dry and then polish it up so you have the letters in a different colour to the background. you could mask it up and do it or use a brush but masking takes ages and a brush leaves bad surface finish.
also when you mask up around the area your going to paint if you fold the tape in half down its lenght you wont get so much of a lip on the edge of the paint when you demask it
it sure is^^^^thats a good idea!!
thats definitelly the plan... just don't know if i use black or white writing.First off , I really like your build so far. I like what you did with the ssd mount and the roof mod . I think above is a great idea , you could block sand just the letters so you have white with black letters.
as said above... either that or the opposite wayI'd say keep it white and pick the GEFORCE GTX lettering out in black
i don't mind at all mate... good luck and have fun doing it.hi CPMFW,
Just catching up on a couple of threads on here with yours being one of them I am following and I hope you dont mind mate but I gotta nick your idea of colouring the accents on the graphics card this is a great idea to make it fall in line with the rest of the build, I currently have one ongoing myself and this may even save me a small fortune !!
I also see Andre re-jig some of his wiring on his ongoing build again nicked from some of your current build, great work dude !
Cheers and looking forward to more updates !!
it's white at the moment so i'm gonna go over it with matte black and sand the letters down till they're white again
240 sandpaper or even finer?
