[BL] Kambo's Scarlet
The new body has arrived!
At first, I just got a confirmation of shipment email from Thomann, without any actual reply to my email, so I was a little confused. A day later I got the reply, they have sent me a new body.
Our colleagues from the guitar department are sending a new body, but they inform you that the body got only a treatment to avoid mold. It is not ready to receive varnish yet. You will have to put foundation before putting varnish. If not, you will have the same problem again and this time we will not be able to replace it on goodwill.
Well duhh Thomann, clearly I know to use primer first but that doesn't help when it's full of holes ;)
Also, the manual of the product clearly states "The first consideration to be made before assembling is to choose the preferred finish of the guitar body.
The basswood body of the guitar is sealed and prepared for various types of lacquer coating. A wide variety of finishes can be procured from DIY, timber and automotive outlets in aerosol cans making finishing straightforward without requiring specialist skills. The use of a dust mask is essential when spraying."
(X)
Oh well, in the end it was all taken care of very nicely!
Internet cookie for whoever can spot the difference in lay-out compared to the old one.
This one is actually sanded and smooth. Does not make a rattle noise when I put my nail on it and drag horizontally across the wood ;)
You can also see from the edges that this one, in fact, does have a wood-sealer/ grain filler layer on top, something the other one was supposed to have, but didn't.
It has a couple of areas that need slight fixing but that just takes a bit of sanding
Did the primer trick to find the rough patches again, there's only really one where the top drops.
And there are a couple of tiny bumps like these, I will fill them up and sand them down! Much better than thousands of tiny holes everywhere :lol:
All in all, this one already looks muuuuuuch better, and I've not even done any work on her yet :)
Oooh I can smell the paint now :lol: oh wait no, I can actually smell paint! cant take it anymore.
Looking good there boss, that matte black was the colour of Aria when I first got her :) years of play made her glossy.
The nut being a white/cream colour annoyed me greatly, so I fixed it :D
The body has a couple rough spots that need a bit more sanding
But there are also a couple of dents/holes in the basswood.
Quite a lot on the bottom really
So I attacked it with some putty :)
This is great stuff cause you just go back over it with water and most the residue comes right off which saves me from sanding again!
Will do a bit more on the front later tonight, and the backside tomorrow.
Then I went back to check on the nut.
Looks good!
(Don't worry about the yellow stripe under the fretboard, that's some left-over masking tape/glue. I'll clean it off tomorrow)
No, I play my acoustic nearly every day even if its just for a few minutes. My axe is my electric guitar, which is hung up on show, but I don't play as often these days, but prefer the feel of it.
I hope you are not referring to the fact its locked away in storage? my heart died a little when I hear guitars not out on show or getting fresh air ;)
Pahaha axe cruelty will not be tolerated :lol: if you don't let them out and forget about them, Feronix new guitar adoption agency will give them a new lease of life :lol: I neglected Aria for years and now look at her she's gorgeous.
Scarlett is looking well nice now dude, the body is coming along really well.
Stop the abuse of neglected guitars, donate now and give one guitar a better life.
:lol:
Did some hole-fixing on the back of the body today, but I couldn't reaaally be arsed to take pictures and basically it looks the same as the front now. Use your imagination :p
After this weekend is when things start to get interesting.
Since we got a new body and for some reason I forgot to test fit the current neck in the new body's neck pocket, I came to the unexpected conclusion that... it didn't (it actually didn't fit into the pocket at all at the beginning, this is after fixing that already).
So lots of filing...
...and sanding later...
It did!
But I needed to repaint to neck. No biggy though
Also, dat awesome matte black on the body!
My masking tape skills are getting better and better with all these projects :lol:
Aaaand both drying from clearcoats :)
Kambo sent me a thing and told me I needed to make a red one, some time later that happened :). Scanned, measured, traced and finally machined from 3mm chilli red frost perspex by Parvum!
JR​
