Big WigglyStyle
Honestly guys he has a point on some of these, I am pro watercooling but in the event of going for temps you can get pretty good near watercooling temps with good air coolers even on graphics cards, take the arctic accellero xtreme (triple fan cooler) is silent and is pretty respectable in temps, as he mentioned the NH-D14 is a good cooler aswell. And for noise you can usually achieve silence on air aswell.
However when you get into the extreme overclocking and loads watercooling obviously will over power any air cooler out there. Especially when going up high in the voltages.
I think the main point of this topic was not to bash watercooling or call it stupid but to point out that you can get silence and low temperatures on air and to the OP he probably noticed a large amount of people saying the only way to get silence and good temperatures are liquid cooling, when it isn't true.
And to be fair my max temps on the CPU are 63c specs in sig 1.25v on the OC and it is quiet...the cpu cooler atleast(on lowest fan setting which doesn't change depending on load), however I desperately want to watercool my rig as my GPU is extremely loud in order to keep it in a respectable ~70c plus watercooling just looks cool and to some that doesn't matter but whatever makes YOU happy is what matters and there will be people out there that (if done right) will appreciate the job you've done which I think is the very reason this forum and I'm sure others have a "post your rig section" simply to display your build.
