SuB
The Webmaster
ok since installed i've had the snap crackle pop bug.. on startup, using windows, doing anything...
it seems tied to the hard drive activity (sometimes it isn't) and I've put up with it until recently. now it does the snap crackle pop rubbish, then it decides to kick the front speakers off and use only the rear left and right speakers...
then might swap to only the front 2 speakers,
and once even swapped to using the center speaker only and the sub woofer
it happens only when I'm listening to music/videos playing games.. and I'll be damned if I'm going to have SILENT windows forever this is starting to seriously annoy me
spec as sig:
Asus sli premium (latest bios)
4800x2 (no over clock and on water)
2gb ram (4x512mb)
7800gt (on water)
x-fi xtreme music
using the silimage for raid 0
and the nforce for 2 other drives
one last thing if i were to setup raid to work on the nforce chip and just swap the drives onto that instead of the silimage ports would the raid 0 setup still work or is it a format jobby?
i'm seriously sick of it now i've heard stuff like putting cardboard wrapped in foil between the graphics card and the sound card helps (sounds dangerous)
using different sata ports and stuff but only by word of mouth.. nothing solid and i'm sure as hell not putting conductive foil anywhere near my xfi and 7800gt on a hunch...
any suggestions chaps?
spec as sig:
2gb ram (4x512mb)
7800gt (on water)
x-fi xtreme music
