AlienALX
Well-known member
OK so this part was done yesterday at home. It uses the exact measurements of the stack inside.
Do note I have not put in the connecting pieces yet. I got the dimensions of each piece from Bitspower's site, and yeah we have a copy of the res and flow meters. I need to now make connecting pieces to make it one entire piece. However, before that I designed the areas that will be carved into for the wood and carbon to go. This should make it easier to understand.
OK, so now imagine that piece with the connecting pieces in place (to mimic the water fittings and connectors) in 5mm silver acrylic, with carbon and wood pieces cut to go in the carve outs.
There. I hope that makes sense. What I now need to go into though is that there will be a piece behind that in 5mm opal, connected behind it. In that I will carve out 5 circles for the LEDs to go in. It will then be screwed together from behind, kinda like a plate res. Basically? this is my "dry run" of creating just that. If it is successful then maybe, just maybe, I will finally get around to making "Fake Plastic Trees". We shall see.
