Devo234
That was my main concern when buying, I wanted something suitable for everyday use and safe at low ohms for a little cloud chasing when the mood takes me. been experimenting with a 24gauge 0.3ohm build but generating too much heat for my liking after a couple of pulls.
The trident is pretty good tbf, at least for my needs and experience. It's the v1 clone I've got. Decent sized deck so plenty of room for building. Posts are a little odd, slotted rather than drilled and it's a threaded cap to secure the coil rather than a screw. They've been a little fiddly at times for dual coil builds, especially when the coils decide to ping it off the centre post before you can tighten it down :lol:
Airflow isn't bad, largest holes are 2mm on the clone if you don't want to take power tools to it and the stock o-rings seemed quite loose/unsecure on mine. Oh and I didn't really like the supplied driptip.
I also looked at the nimbus (air holes are minuscule and no adjustment so you're stuck with whatever you drill them out to) and the atomic (deck a little too small for a novice builder like me).
Overall though the trident was the best choice for me from what my shop had at the time.
I think i will get a trident because i wanna experiment with ribbon wire coils and the slotted posts will be easier to use with ribbon.
Ive ordered a kayfun clone which was shipped out today so hopefully it'll arrive tuesday/wednesday. Really looking forward to that
Mathius if no one replies before i get home from work ill answer your questions then cause doing this on mobile is a pain
