trawetSluaP
Member
Hi,
I purchased a H320X2 Prestige CPU cooler this week and must say I'm thrilled with it. Not only does it look incredible but the cooling performance is fantastic!
The one issue that concerns me is that on the CPU block the silver fittings connecting the hoses to the block. One of those fittings is so tight I cannot move the fitting, not even to rotate it to aid with the hose position. The second fitting is loose enough that I can rotate it and it does wobble a little. Is this normal?
There are no instructions in the box on how to loosen or tighten them so I have contacted Swiftech too.
Also, is it normal for CPU "Package" temps to be higher than the CPU cores themselves? At idle to "Package" temp is about 5C higher but under load it's the same as the highest Core temp.
Thanks!
Paul
Thanks!
Paul
