Apologies for the missing photos. I will do a little to catch up guys. OK, so the last time you guys all saw the Triad it looked like this.
I had not touched it for over a year. I decided to strip and clean it all recently, and then do some upgrades. Upgrade 1, 14 core 28 thread Broadwell E Xeon
It clocks to 3.1ghz on up to four cores (and selects the best) and then clocks to 2.8ghz on all 14. It's pretty bloody impressive for £360. I could have probably ran it in the board I had, but I decided to buy a new MSI X99 SLi Plus for £117.
Far better and much more befitting of the build tbh. I bought this 180gb M.2 drive for another build, but decided to use it on the upgrade.
It's nothing too fancy, cost £30 does about 550 R/W. Any way, then I got this.
And sold the Maxwell Titan X. Here is how the rig looked then, and still does now.
And it was all sort of going OK. Fallout 4 makes the fan spin up every so often, but nothing terrible. So my plan was to basically make my own Hybrid doodah for it and have the GPU AIO cooled. However, last night I met this lovely young woman.
And my GPU went ballistic. Not sure if you guys have played this yet but due to the *incredible* graphics and total lack of cut scenes my Titan XP just went mental and the fan immediately jumped to 100% and stayed there for twenty minutes. Then I touched the back of the card behind the GPU and bugger me, I wish I hadn't. I had to do something drastic and quick.
So it was OCUK to the rescue again.
I'm not quite sure how this is going to look. I want to make it look like a heart with blood and veins, but not sure how well it is going to drop into the blue. However, at the prices I paid I could not help it. I can not afford to spend £18 on each fitting, these were £2.99 each.
10/8. I have ordered 12. Why not at that price eh? OK, so I also ordered this. You'll see why shortly.
As well as this.
And then this.
OK, so that rounded up the OCUK order and it has been sorted and will be here soon. Then I wanted a block. So I decided on this.
And then I looked at back plates. They are £23 for an AC one. However, for £34 you can have this.
And TBH? I have never had a GPU get so hot on the back. So I figured that was a bargain and ordered that too. What you do is remove the edge connector from the block and bolt on the back plate one which then cools both. Pretty sweet.
For the pump I decided to use this again @ £10.
I've already got one cooling my other rig and it's excellent. Ceramic bearing and shaft etc, very strong motor. No point spending £100. Any way, that is what the coupler fitting is for, so I can fit it directly to the bottom of the tank. I also ordered the tubing.
And had two fittings left over from before. I have one of these.
And one of these in white that I need to paint (it's also BP)
I am going to replace any green Orings with black ones (I've got tons because Monsoon give you two in different colours).
Any way, yeah, not sure how the red will fit in but I wasn't spending over double to find out. I will paint the white coupler black with matt model paint and I need to make a weird bracket to hold the pump and tank to the 120 mount.
