sfelock
You can always slice the tape down the middle if its too wide, so long as your base coat beneath is set for the allotted 24 hrs it should not peel.
True true. And yea I actually forgot how low tack electrical tape really is
Aye its more a gum than an adhesive and like frog tape its a uniform bond to the surface, masking is one job I aways despised when I did painting & decorating at college but soon learned that preparation is the most vital part of any job, nearly as important as using a good quality primer before painting. It means the difference between a good finish and an epic finish. If your still unsure try out different techniques on a piece of scrap. We have 5 weeks left so take your time, I know I've said it before sorry.
	UPDATE 11/8/15
Ok so I forgot to snap some in progress shots while I was working because I did this at work, but, I took apart and paint led my old H60 to match the rest of my build.
Nice job on the cooler!
Thanks man! She's a bit dusty still but my canned air keeps freezing up. Going to clean it good, before she gets installed.
On a side note, I'm beginning to install hardware, just waiting on the new ram kit to get here along with the acrylic sheet for the psu shroud.
Coming along nicely. I really like the blue hard drive trays showing through from the motherboard side. A nice touch.
	:drool: I do like that fella! It's turned out really really great. Kudos to you.
