UPDATE
This holiday weekend was spent relaxing with my wife. I worked on the rig but didn't get any free time to toil on my case.
Here is the power switch I copped from CaseLabs. This will be mounted in a "stealth" position. I will not be using the stock front I/O panel. So, I decided to allow the stock power button to serve as a dummy switch. I will be the only one that knows how to turn on SkyNET when I'm done. Kinda like Biff's car in the Back to the Future franchise.
This is my rig with all the components and wire extensions. I didn't get the 8-Pin EPS extension because it won't show that much when installed, and the stock Corsair cables are sleeved black. It should just blend in when finally installed. I might change my mind as the build progresses. Playing with the white tubing over the past couple of weeks has sold me on using a white colored coolant. The kinking you see isn't as bad or restrictive as they look. The angle I used for the pic makes it look terrible. And bleeding that "St. Louis Arch" of a connection was no picnic.
The copper base of the CPU block will not be that visible through the coolant, so it not matching the base of the memory block is fine.
The CPU to memory block connection will be replaced with some Bitspower BPS90s, C48s, and Crystal Link. I have decided to use acrylic tubing through out my build pending how this Crystal Link looks when installed. Acrylic tubing appears to be the current craze in liquid cooling. I recently viewed a build log with the new Corsair 900D using all acrylic. I like acrylic in short lengths. Not going from one side of the case to the other. The routing I have planned for my build is perfect for acrylic because aesthetically it will prevent by MoBo from looking smothered, allowing the components to be the main focus. And it will cut down on the amount of fittings I will need. That stuff should arrive this weekend.
I'm also thinking about painting the exterior of my case gun metal gray. I thing that would look killer against the aluminum Lian Li case wheels.
The guts will remain flat black.
Stay tuned...
