JayCobs
UPDATE!!!
Yesterday I finished the true sliding MoBo tray mod. It turned out wonderful. My initial pics of this were sans the top guide rail. Here I will go over installation of said rail.
I recently picked up M4 and 6/32 taps with matching drill bits. I used socket cap M4 bolts to mount components on Free Bench. I don't know why I am so fond of M4 bolts at this time. They are aesthetically pleasing to say the least. I used them here as well.
In this pic I have already drilled, tapped, and bolted the upper guide rail. After completing this mod I thought to myself "Corsair should've have offered this feature". It wasn't that hard to pull off I must say.
Here's a close up of one M4 fastened.
A pic of the business side of the mount. This section of the case roof the upper rail is mounted to is where the original MoBo slides into tabs. This section is very sturdy and perfectly placed for this mod.
Extra thread cut and filed down.
The completed mod from the back. Upper and lower guide rails visible. :rock:
Business side finished shot. The upper guide rail is hidden. Once painted black it will blend nicely. The lower guide rail will be completely hidden by the rad-fan combo.
Today I will cut some 16 gauge sheet metal to finish the blanking plate for the MoBo tray. The current aluminum I used is flimsy and not up to snuff. Hopefully I can pull the gap flush between MoBo and the I/O shield. It's bugging me! :cussing:
After that I will be contemplating how to clean up the PSU mount. I am considering the Lian Li PE-01 Power Supply Extension Bracket - Black (PE-01). I feel that will clean up the mount the most when combined with the lower support bar I already have installed.
Stay tuned...
Stay tuned...
