JayCobs
Greetings. New to the site. I heard great things about this place and decided to give it a go. :wavey:
I live in the desert and summertime proves to be quite challenging for my PC. Having my PC sound like an airport to get sub-par cooling is not the business. And trying to overclock for gaming; forget it. I'm fairly new to the modding scene. I have built and repaired computers for friends and family for a while. I built a "practice water cooled rig" just to get the hang of it with parts from Home Depot. Turned out pretty well. This will be my official first attempt at a full liquid loop.
Due to budget constraints I will split my build into two phases:
Phase 1:
Corsair Obsidian 800D
AMD Phenom II X4 965 Deneb Black Edition
Gigabyte GA-990FXAA-UD3 rev. 1.1
G.Skill Sniper F3-17000CL11D-8GBSR [2 X 4GB]
MSI R7950 Twin Frozr III 3GB GDDR5 V2 7970 PCB [2 of these]
Heatkiller GPU-X3 79X0 Ni Bi Silver water blocks and back plates
Corsair AX1200
Black Ice SR1 480mm rads [x2]
Noctua NF-F12 120mm [x8]
Swiftech MCP655 [x2]
Bitpsower Matte Black D5 upgrade kit [x2]
Bitspower Dual D5 Mod Top / Extreme black
Bitspower Dual / Single D5 Top Upgrade kit 150 - Black
Antec Kuhler H20 920 [from previous build]
Phobya 4-pin to 6x 3-pin fan splitter PCB [x2]
Lian Li case wheels [silver]
A cavalcade of Bitspower compression fittings
With the Corsair 900D dropping in a few weeks I'm not sure if anyone has an interest in the 800D anymore. I hope so, cuz I do!
And so it begins...
This is a pic of my rig prior to the upgrade:
Not a bad look. However in the summer my temps were horrible! :blink:
A good percentage of Phase 1 is complete. I will now catch you guys up to my current state.
Mounting the Lian Li case wheels. I will later rearrange their positioning.
I'm positive this case is going to be close to 70lbs when complete. Mounted some spring loaded case handles from MNPCTECH to assist with lifting.
Here I have gutted most of the case and removed the MoBo tray for my upcoming removable MoBo tray mod.
Barely visible is the now skeletized [is this a real verb tense???] Corsair 800D. It is literally a box with case wheels. Time to cut some blanking plates and start on the removable MoBo tray mod.
Here's a pic of the mount where the PSU will be relocated to. I will speak on that res/pump config shortly.
This is what I initially planned for the build. A single D5 pump with res top mod kit, and an external fill port. However, I have abandoned this course for a more powerful pump config. The new pump config will not be mounted to the Mobo tray. Here a first look at the blanking plates cut and installed. I fabricated a mock AX 1200 [blue box] to make sure as I progress I do not invade its footprint in the case.
This is a close up shot of the stock mid-plate mod. I cut and filed it to keep some of the structural integrity of the case, and to mount the guide track for the removable MoBo tray.
This is where I took a deep breath and dove in. All or nothin' baby! Point of no return. Chopped the rear of the case for the removable Mobo tray mod.
Here I'm bending the new Mobo tray.
And here it is people! The first [I haven't seen another one on the net] Corsair 800D with a true sliding removable MoBo tray. I was so happy it worked out. If it didn't, I was gonna throw this case of a near by parking structure. Then fab a new case from scratch. Whew...crisis averted. The tedious part of this mod was SLOWLY filing the bottom portion of the original MoBo tray so it fit perfectly in the track. I think it took over an hour to complete the filing. Well worth it.
The next day after this milestone was completed, I got a knock at the door...
My shipment has arrived!!! :dribble:
This is over 90% of what I need to complete Phase 1. Felt like I was 4yrs old on Christmas Day again. What a feeling. The shipment arrived 20mins before I had to leave for the plantation. Best believe I came super close to tellin' my boss "Not comin' in today!". I took some parts to work with me to assemble and ease the anxiety. I work 4 days a week, 10hr shifts. 10hrs was just TOO DAMN LONG TO WAIT MAN!!! :wacko:
The goodies
What I took to work to play with. Luckily the package arrived on a Friday. I have the weekends off which helped my sanity remain intact knowing I can work on the computer for the next two days! tee-hee
This is a shinning moment here. All the measuring, remeasuring...asking myself over and over is it going to fit? Will there be enough room? Man...came down to a couple of millimeters. I WIN! both rads and fans fit. And yes you are looking at TWO 480s in the bottom of an 800D. Witness.
At this part of the build I need to use my actual components and not mock-ups to move forward. Hence, I had to break down the temporary house [CoolerMaster Scout] for my components and use my laptop. This is killing me softly. I went from a beast of a machine, BluRay, video games, and 3 monitors to 1 monitor and sluggish by comparison performance. Man, I need to get SkyNET back up and running A.S.A.P.!!!!!
I am using MASSIVE MoBo stand-offs for my planned cable management. I'm going to cut holes for each cable pass-through underneath the MoBo. This will give the illusion of the wires "crawling" from under the MoBo instead of simply passing through the tray. Should look awesome at the end. What did I use to make the stand-offs you ask? A chopped up grey BIC pen housing. WIN.
Ahhh...the beautiful MSI R7950s all dressed up and nothing to process. :lol: Also you get a sneak peak of the pump/res config here as well. SkyNET is gaining a lot of weight and there is no liquid in the build yet. My earlier estimation of 70lbs currently way off.
Here is a rear shot of the removable MoBo tray mod. Also this is the build progress to present.
And here is Phase 1 to current. I have the PCI cables connected to the GPUs [orange zip ties are temps]. You can see how they come from behind the MoBo. Visible is one of the splitter PCBs for the closest facing fans. I have Velcro-ed my Intel SSD to the PSU. The fans are currently being powered by a spare PSU behind the build. So, outside of some Tygon tubing and a few fittings Phase 1 is near complete. I still need to tighten up some odds and ends with the MoBo tray like mounting the MoBo tray rail permanently.
I would love to hear ideas of where I should or you would go with the build from this point. I'm still contemplating putting another 480 in the roof. It's stock cut for a 360 and that might be what I go with. Updates will be minuscule until I can place Phase 1's final order with FrozenCPU. I gotta get some debt cleared up before I dump more cash in this build.
Stay tuned....
Phase 1:
Corsair AX1200
And so it begins...
The goodies
Stay tuned....
