Project Nebula: TJ07 Build
I love the bitspower picture :o What do you use as background? For a photo of a fairly small area like that it might be a better idea to use white (bleached) A3 paper because it's flatter. Auto colour correction in photoshop and background's usually gone :)
This makes me want to go the watercooling way, but will have to find a job first >:'(
Thanks, I'm using a white sheet. I would have liked a thicker king size sheet to use but I didn't have the time to go looking for one so I just made do with that :D
An A3 would be enough to cover the floor part but not the background, I'd need a bigger size for that and then there's the problem if it creases or rips :eek:
A sheet is much better I think and if you get some good lights on it then you're set! Most of my pictures I take are in the morning when the sun is out nice and bright and it's shining right on the sheet which makes taking the pictures a breeze.
name='tinytomlogan' said:
Im deffo a bitspower convert dude. Project startign off great btw keep the updates coming.
Thanks Tom, will keep the updates coming. I'm waiting on your next YouTube vid to hear that voice of yours :haha:
Cheers lads! :wavey:
Moar pics!
I'm spray painting today (nice and sunny) but it's not yet finished so no pics of that today (Well maybe later ;))
Got me some P-Clips to help with the cable management on the back of the motherboard tray.
Nice little update moogle, one question, I like the P clips, but how are they attached? Screw? That would be tricky in some locations
Cheers Peter. Yep they are attached by screw, the mobo tray has alot of spare threaded holes and I've bought a packet of socket head cap screws and if I need more holes to hold the cables down where I've routed them I'll either use the pack of cable tie bases or I'll drill a few more holes and tap them to use more screws :)
Bigger picture update this time...
Lots of lovely braid and heatshrink
GPU Block + Ram backplate, just forgot to take a picture of the backplate but you can find out what it looks like :)
Going to have the Blue on the CPU + NB loop and Green on the GPU loop (not suprising eh) :D
These are here to replace the 2 x 92mm fans at the back...
The fans for the rads. Two more on order for the roof of the case, everything nice and Scythey.
Done my final two orders but a few bits are out of stock :(
I shall have to wait but I suppose that'll give me time to get the measurements/drawings for the custom bits.
I'm eager to see the outcome now, it's weird that this is on every forum I visit :P I get mixed up reading things 3 times and then realising I've already ready it :P
You've got some very very nice parts there :)
One question; where did you get the P-clips from? and what material are they?
Thanks,
Max
Thanks,
Max
Thanks Max,
These ones are Nylon 6.4mm (1/4") ones and I got them off eBay :)
name='maxw' said:
Thanks, found them now :)
Good luck with the build, I'll be watching it all the way!
Thanks, and no probs ;)
name='themcman1' said:
Where's this stuff from? I've been looking at sleeving for ages but seem to be getting nowhere. :)
Mines a mixture from alot of shops :D
I got some from ChilledPC, KustomPC and some from eBay.
