name='fatty' said:Mate have you not seen I am using a 210W heatload to test the unit 210W that is quite a lot of heat phils unit would hold that heatload at 18-20 degrees this will hold it at -0.6 degrees???
name='fatty' said:Well I have found I can hook the unit up too a mach1 controler so you can set the set points ie you can set it so you will have no condensation or set it for a slushy machine depending on your needsthis is ver very good news in my opinion so if you dont want condensation you could tune the system via the controler for what you want
fatty said:Yeah I have thought about my own chassis but I am too busy to sit down and design one not just that but then I would have to get it built which would then add to the price loool
