OK, well I will write this update for the second time today. Tried to do it on my lunch break earlier, unfortunately I pulled a dumb move and somehow.... well you get the idea.
So I worked on Defiant for many hours over the weekend. Most of those hours have been spent on the PSU sleeve. Well, not most. Many though. Anyway.
The sleeve is looking quite nice.
The amount of wires that come out of this PSU are.... many. So much so that I have used up my sleeve and still have wires to finish. Worst problem is that it takes about two weeks to get here. So that will be on pause for now. Good news though
I got parts!
With a little bit of bartering I was able to get most of the parts, but the video card is still on the waiting list. It feels good to get new parts
So I took everything out of the boxes and and did a bit of bench testing to make sure it all works.
Grabbed a few random parts and set up little test setup.
After playing with a little overclocking, some bench tests and general toying around I was having some fun. After making sure everything worked at idle and under load I proceeded to tear it all back down and get some water blocks on the motherboard.
The blocks are nice, perfect fit and general ease to install.
After mounting the board in the case I set up a loop so that I could play with my new toy a bit.
Without the GPU in place it looks kind of odd, but once it is in, there will be a few changes made.
I made sure to leak test for 24+ hours with some extra coolant to make sure I didn't have any drips. The reservoir was a little drippy at first, but I had extra o-rings EK had sent me. fixxed the problem right up.
I will probably be changing the fluid to a different color, and might change the tube to white. not sure yet, going to debate on that for a bit. Speaking of the reservoir, my buddy is a machinist and made me some sweet little mounting blocks.
I'm going to finish up a little bit of work on the power supply tonight and get it mounted in the case. I still have the lines for the video card to sleeve, but it will be about two weeks before I can start on that. It's quite surprising how much sleeve I have used so far. only a few lines left to sleeve though, need two for the video card and one with molex ends. I got the SATA connections finished and they look very exceptional. That will be for a later day though. I need to have a few things to hold onto
I did have a few new ideas now that I have a few parts, and have some ideas for new parts
Back to work I go
Edit: Just one more cause it turned out to be decent
