Whats up everyone!
It all started today when i was on my way to take my stuff from our supplyroom for the appartment and move them over to our worksop, i had been told the same day that some/someone had been down there and many locks had been broken aswell and it was a big mess, I went down and took everything that i could find from my boxes, I havnt found all the part for the case yeat, the hose and some fittings and some other stuff but they are somewere in that mess i belive, thats my next daily project :/
On the way up to our PC workshop I saw the dremel pacage ... the first that idea that struck was that i have to start cutting into the case anytim...and yeah...a short while after i wasa on to it
The case is almost ready for some ALU-welding
Now some pictures (the radguard ist flush because the doble aluplates are in the way, i mean where the case is assembled in two pieces)
I also removed the little notch where the two pieces meets (does not show),now its not in the way for the rad anymore, everything should be fixed better later, after welding, the rad will be placed right up to the edge later as you maybe have noticed
Over and out !
Over and out !
