Project Chocolate Temptation
Hello everyone!
I have to say that i have got some complaints that I have not done any updates in a while :/ ... The truth is that iat is so... but I did anyway take my thumb out and started to play around with all the things that I had at home today, its nice to finally have some sparetime afterall
I dont have that much to tell you guys but today I wanted to see how everything is going to sit, I even did the planing for my tuberouting and what should be done on the chassis before it prepares for the ALU-weld and paint preparation.
I have been thinking of re-sleeving the power supply ... What do you think guys?
What I have at home right now is: Copper Brown, Vanilla Sands, Black, Color-X, Red, B-magic and little else from MDPC-X, including mass of different colors from Djungelapa
I haven't decided that yet...and I will also crimp that sleeve aswell!
I have been thinking for a while if my powersupply will work 100% to runmy system in LOAD :/ ?
Here is todays Picdump
I really have to fix the soft box that I have been planing to make for some time now and never had time to
Its a shame that Asus don't do a M-ITX Sabertooth board - that would compliment your colour scheme perfectly.
Hello Guys !
Had some time over tonight to test out my waterblock for the Southbridge... but for my surprise it didnt fit of course, damn it...I got really mad :@!
The microcoil is in the way and dont let the waterblock to rest as it should do... but I had a brainwave and started to sketch out a self-made ​​water block for the Southbridge and the waterblock
I just need to get the help of a CAD expert now because I do not have enough CAD knowledge to make the waterblock properly.
If you are the person please make a comment and tell me what you need
Here is how it looks anyway I was going to do something in sketchup but I dont know if it's even worth it?
Before you start complaining about the pictures I just want to say that I took them with a weak desk lamp as light source, something weird happened to my memory card and pictures have begun to be quite strange and grainy can only read the files from the camera and the SDcard is incredibly slow now
... I really have to get a new one!
The microcoil....
I always get excited with this build log! Looking GREAT!
Bit of a tight squeeze with the NB/SB blocks on that Zotac board.
