Problem with start MACH II GT
it didnt arrive busted, iv got no idea, too slow usually means a leak but its going down to the temp...
name='justin' said:
it didnt arrive busted, iv got no idea, too slow usually means a leak or just not reading a molex signal
It doesn't sound like bad contact it sounds like a bad board if you have flashed it correctly and it still reads the temperature wrong then it is a faulty control board it WILL have to be replaced
Thanks Phil, maybe I will need your help with my reseller because he doesn´t understand this at all.
Yes thanks for help all. Fatty you know it is very hard sorted this problem when I am so far from places where could it be solved, but I hope I solrted it as soos as possible. I am a student and I was spended for mach all year and you know what does mean money specialy before christmas and so on. If this problem come after one using mach so I dont tell nothing but after one month it is really soon for thing which cost so much( for me cost so much)!!!
Hi all, mach seems after two days ok, shows room temperature and no show sensor fail. But I cant test him because i have no seal string, I cant find it in my country and Phill tell me that cost a lot of from england. So can somebody help me?? I live in czech republic so maybe somebody from germany or poland?? If i RMA mach now so it will be for nothing, because they wont see the problem... I NEED SEAL STRING :-DD
jirii sounds Like good news ok start the mach without it connected to your pc all you have to do is touch the two pins from the blue and white wires together and see if the mach2 starts and runs down to temperature
I am not sure what it would cost to post to the czech republic but I may be able to help you out
Hi fatty
I tried this three time and he go down to -70 and when I stop him go to 22 my room temperature it seems that he is "now" "alright" so I cant send him for RMA because they cant see nothing.
P.S. PM me if there is any possibility about seal string and thanks for halp man;)
You should find seal string at your local plummer store. It´s somthing they use often.
Sorry for my bad english. Hope you understand :D
Hi all, I am really sad, I hoped that I will have mach II gt mounted on my pc during christmas, but that german shop send me email that they are nto able to deliveredseal string until January, but they had on www last week that seal string are in stock thatś why i ordered there. :-((
