with the interior of the Stryker being white, alot of the darkness will lighten up automatically.
main color will be white. secondary is black and accent is red. before the pci socket color change, it'll
have to be installed in the Stryker case to balance the color proportion. looking at it in the Trooper
is misleading.
another possibility to look into is changing the red to OC3D blue to represent the water of life
for ORCA. vinyl wrap boots surrounding the red bits in blue, for a suggestion.
genuine pain for the wrap or air-brushing the red. like i said, just a suggestion.
airdeano
I Love this idea, it would look amazing if tom has the time to sink into it to do it properly. The blue would really tie in well with the name and personally I think would work better with white and back than red. Although I think red could work too but in a darker shade. Interested to see it in the Stryker as Ardeano said with light in the white interior.
Also if you left the chrome and and just painted the black bits on the blocks white you could get nice effect similar to the white black and blue/red as in this build.
http://forums.bit-tech.net/showthread.php?t=204450&page=13
Just my 2 cents looking forward to more updates and good luck with the build
