SuB
The Webmaster
Settings don't matter, aids on or off, personally, the only aid I use is ABS.
I have the driving line on but change to my own line for certain sections.
Damage is irrelevant, easier to have it set to off so that you don't have to restart the time trial session if you do make a mistake on the lap. If racing, then yes it needs to be on, but for timed laps, no point.
Ultimately, if it is valid on the leader board in game, it's valid here.
Where do you change the driving model? What does it change?
I have set another time of 2:39.917 with no aids and full damage on. Just using auto gears, auto clutch and driving line. So I would say that the aids do slow you down.
Of course they matter, they make the skill required to complete a lap a non-level playing field. While you or I might be able to control the power of some cars without things like traction control, others may not, and just having the game do it is an unfair advantage overall, even if that can ultimately make you slower. ABS makes a *massive* difference in how fast/safely you can stop a car in PCars, and is a huge advantage technically over not having it.
Damage isn't irrelevant, there are some sections of track where if you choose to cut a corner in some way it would cause enough damage to make a difference to a car's performance, that's a risk that shouldn't be negated by cheesing it with no damage. The lap needs to be clean
I just double checked driving model, it sounds like this is mostly left over from development (which is why I thought it still made a difference) apparently all it does now is set the level and amount of assists on by default, so ultimately it's just a sign of what assists you had it set to when you booted up I guess. That site shows assists so ultimately it doesn't matter really
Nice laptime
