Hi, my name’s Joe and I’m 13 and from the UK. I have recently built my first rig and I have been running it in my room for the last few months on air cooling. It gets the job done, but only just, it is very loud and as I am typing now I can hear the fans over my over ear headset! I am looking to water cooling to help me with my problem of just getting by with load temps of over 80C while playing some of latest games and the massive issue of my fans sounding like jets taking off under load. So without further ado, I’ll show you the spec of my rig.
InWin Dragon Rider Full Tower Case
AMD FX-4170 Processor
AMD Radeon HD 7870 Graphics card
Kingston Hyper-X Genesis 1600mHz RAM
ASUS M5A97 R2.0 Motherboard
FSP 450w Power Supply
And the 4 stock fans that came with the case (I removed the large 200mm fan a few days ago)
Here is a pic of my rig (I know the cable management is hard to overlook):
I am hoping to have enough money left after purchasing the water cooling to but a new PSU, I’ve had my eye on the XFX XXX Edition 650w for a while now due to me loving the aesthetic, it being 80+ Bronze and the fact that it is semi-modular for improved cable management.
So now down to the matter itself, I don’t know whether I should buy an AIO water cooling unit and just buy an aftermarket GPU air cooler for £65 (The Arctic Cooling Accelero Xtreme III) or make a custom loop for another £100 and include the graphics card water block which is only £60 (The price of the Arctic Cooling Accelero Xtreme III) and use less fans and have a quieter and cooler loop (also the aesthetics could be made infinitely better)
This is a list of components for a custom loop including the PSU and fans required:
EK Supreme LTX CSQ AMD CPU Water block: Nickel Plexi Specialtech = £33.32
EK FC7870 CSQ Full Cover Water block: Nickel Acetal = £54.96
EK CoolStream XT 240mm Dual Radiator Specialtech = £33.33
OR Alphacool NexXxos XT45 240mm Dual Radiator: Full Copper = £33.50
2m Masterkleer 3/8” ID – 1/2 “ OD Clear = £4.82
EK PSC 1/4" Thread Compression Fitting for 3/8" ID - 1/2" OD x6 = £14.94
XSPC X20 200 Single Bay Res and Pump = £29.50
OR XSPC X20 750 Dual Bay Res and Pump v2 = £49.96
Mayhems X1 Premix Fluid 1 Litre: Blue / UV Blue = £6.66
XSPC 120mm Quiet Case Fan 1200rpm x6 = £20.80
XFX XXX Edition Semi-Modular 650w = £62.36
+ 20% VAT = £55.00
TOTAL (APROX): MAX£350/MIN£250 (Minus GPU Water block and PSU and lower pump)
All in One Watercooling + Air cooled GPU
Corsair H100i = £92.95
XSPC 120mm Quiet Case Fan 1200rpm x6 = £29.70
Arctic Cooling Accelero Xtreme III PWM Quiet Graphics Card Cooler = £64.01
TOTAL: £249.02
Please comment and tell me any ways I could improve my custom loop or how I should decide on what I order.
P.S. I am buying the majority of my products from Specialtech. If you have any other recommendations for somewhere else to buy my products in the UK please just say in the comments!
Thanks in advance!
+ 20% VAT = £55.00
TOTAL: £249.02
Thanks in advance!
