trawetSluaP
Member
Hi all, hope everyone is doing well.
Last night I was casually watching some footy and my PC BSOD. When trying to reboot my Mobo provided an error code and said "Detect Memory".
I opened my PC up to check the RAM to discover everything was extremely hot to the point I nearly burnt m hand on the GPU backplate.
This was a result of my EK D5 which had stopped working. Not spinning at all. I unplugged the power and PWM header and plugged them back in and the pump was working again.
I then re-seated my RAM and cleared the CMOS and now my PC is working fine again.
However, I am a little concerned over what caused the pump to stop. It wasn't a total failure as it's working perfectly again although I am worried it could stop again.
I suppose it is possible the power connector came loose but it didn't seem to be when I inspected it.
Has anyone else had an issue like this before that can shed any light. Would it be worth contacting EK or are they likely to not be interested given the pump is now working again.
I am now tempted to switch back to air cooling as this experience has dented my confidence of the loop I have considerably.
